Order Ford 8N Parts Online
Mildly OT: 8-volt 8N Has Nine Lives
A. Bohemian
03-14-2007 09:00:24
Last night lightning hit a utility pole about three hundred feet from where the 8N is parked. I mean a direct hit.
This was a 25 ft. pole and only three or four pieces longer than four feet are left. The rest exists only as splinters, some of them two feet long and almsot as sharp as a stiletto, scattered out over a fifty-foot or so radius.
The winter grass, new spring growth, oats, etc., right at the base of the pole appear uninjured.
A. Bohemian
03-14-2007 11:08:28
 Re: Mildly OT: 8-volt 8N Has Nine Lives in reply to A. Bohemian, 03-14-2007 09:00:24
I went down there today to get a closer look and take pictures, and the thing had VERY little charring on it, mostly little spots a couple of inches in diameter in the center of the pole (now exposed).
These spots seemed to be at regular intervals of the same length of the amount of pole left above the ground (approx. 5 ft.) and may represent nodes in the standing wave that must have existed in the length of the pole for some number of nanoseconds!
Most of the explosive work, though, was obviously done by steam as Dell says.
Splinters still attached to the pole are splayed out (like your hear does when you touch a Van de Graff generator) from the like charges on the splinter ends.
Jim.UT
03-14-2007 10:33:16
That can make life exciting!
Dell (WA)
03-14-2007 09:06:27
Welp, clearly them lightnin' electrons lookin' fer GROUND and wooden utility pole was slowin'em down. Pole explodes from "moisture" in wood, steam pressure you know..... ..Dell
