dunk, advice
9n again
03-15-2007 18:45:50
Dunk i posted below about wet and dry compression you commented , but do you thinkI shoudl replace the head gasket?
Thanks
Sean (TX)
03-15-2007 19:26:08
 Re: dunk, advice in reply to 9n again, 03-15-2007 18:45:50
If you have studs with nuts on the head soak them for a few days with penetrating oil..
Dunk
03-15-2007 18:52:18
From all the information you have posted so far, I am concerned that you have a head gasket that has a water jacket, to compression chamber leak.
(but I may be all off my rocker, who knows?)
That would be on #3 counting from the front.
But ifn you want me too I can tell you the firing order from starting at the seat (in the AM).
9n agian
03-15-2007 18:54:12
 Re: dunk, advice in reply to Dunk, 03-15-2007 18:52:18
sure id like that, also you can tell me what kind of gasket to get if you thinki shoudl get one
thanks
Dunk
03-15-2007 19:01:52
 Re: dunk, advice in reply to 9n agian, 03-15-2007 18:54:12
I am not at all partial to the metal ones (I don't have a good reason for that), I like the fiber ones.
