Order Ford 8N Parts Online
8-volt 8N Finis
A. Bohemian
03-17-2007 14:19:36
Well, today I went over to drain the tank and put in fresh gas and the fresh battery.
Low and behold, the fuel system is plugged, ahead of the sediment bowl.
I removed the bowl and tried various things. Cut-off in "Main" position. Cut-off in "Reserve" position. Cut-off opened slowly, one turn at a time. Fuel cap on. Fuel cap off. Nothing I tried got even a trickle of fuel out of the cut-off valve assembly.
So, Pilate-like, I have washed my hands of this tractor. The owner has already found a good mechanic (he knows everybody in our end of the county) and will take the tractor there to have the tank cleaned and carb evaluated.
Many thanks for your patient and useful replies. Enjoy your Fords. They are interesting little machines.
Bob Harvey
03-17-2007 19:30:47
 Re: 8-volt 8N Finis in reply to A. Bohemian, 03-17-2007 14:19:36
Awww, ya give up too easy.
