Starting problem
RDAllison
03-18-2007 20:26:32
Hello,
I have a 1949 8n and I cant get it started.
The spark plugs where not sparking so through a series of events I have replaced the ignition coil, points, condenser, rotor and distributor cap. The spark plugs are now sparking.
I have thoroughly cleaned the air filter and carburetor. The carburetor has suction at the air intake and there is gas in the carburetor bowl. If any one could help I would appreciate it. Thanks, RDAllison
DON TX
03-19-2007 07:07:25
 Re: Starting problem in reply to RDAllison, 03-18-2007 20:26:32
I'd shoot some ether in the carb to see if it will start at all. That will confirm spark or gas prob. Compression may need to come up for standard start. 4 yrs could have rings stuck, bad compression, hard start, etc. HTH
DON TX
Colin King
03-19-2007 06:29:08
RD, Try new Autolite 437 spark plugs. Gap to 0.025" If you flood your engine, often the plugs will not get hot enough (because they leak to ground) in these low compression engines to ignite the air/fuel mixture.
Once you get your engine hot, you can swap out your old plugs one by one. You'll then have 2 working sets!
Colin in Minn
Bob
03-18-2007 20:31:11
If you "flooded" it while it had no spark the spark plugs may be "wet" and NOT firing when installed and "under compression".
(Safely) burning them clean with a propane torch or replacing them MAY be necessary to get the engine to start.
RDAllison
03-18-2007 20:47:26
 Re: Starting problem in reply to Bob, 03-18-2007 20:31:11
Yeah that might be the problem but it has not run for about 4 yeas I think (It was given to me to fix-up).
old
03-19-2007 08:06:00
 Re: Starting problem in reply to RDAllison, 03-18-2007 20:47:26
If it has sat for 4 years first thing you need to do is fill the cylinders with tranny fluid and let it sit a couple days. Be sure to put the plugs back in to keep dirt etc. out. Then pull all the plugs after that couple of days and spin the engine over to clear out the cylinders. Reinstall the plugs and try to start it up. Doing the tranny fluid thing unsticks stuck rings and cleans the engine out. BTDT many times with old tractors and most of the time doing that helps a lot
RDAllison
03-20-2007 11:02:13
 Re: Starting problem in reply to old, 03-19-2007 08:06:00
Hey,
I put some tranny fluid in the spark plug holes and is came out the exhaust and carb. I think I put too much in is that ok? Thanks, RDAllison
old
03-20-2007 11:31:29
 Re: Starting problem in reply to RDAllison, 03-20-2007 11:02:13
Thats ok becuase all that has happened is that you have a valve or 2 open so its also getting down and around those valves. It can also help the other valves if you slowly turn the engine over a little at a time so the other valves open and do the same thing
RDAllison
03-19-2007 19:49:35
Yeah I put some marvel mystery oil in the spark plug holes a few weeks back . Is that the same thing?
Thanks RDAllison
old
03-19-2007 20:25:08
 Re: Starting problem in reply to RDAllison, 03-19-2007 19:49:35
Its close but cost 3 time as much and does the same thing. I like to fill the up full so the valves and cylinder walls get a good coating and cleaning.
