dell you might have hit something gas tank ...
john hunt
03-19-2007 19:34:01
i never had my 2 n cowl off, but it seem to be that slow down of fuel feed, because of the vent plug. could u show me about where it is. or where i have to look at. if you have picture of it that would be great. i know a black widow live in right now he he ...
Henry M
03-20-2007 16:58:41
 Re: dell you might have hit something gas tank . in reply to john hunt , 03-19-2007 19:34:01
Jeff
Man I don't know. I have never had a set up that needed the rad blocked in cold weather if the thermostat was working properly.
TIMW(PA)
03-20-2007 05:01:03
 PIC in reply to john hunt , 03-19-2007 19:34:01
third party image
Here"s a picture of mine. Some people say you can"t go straight through as the holes are offset from the outer and inner layers, But mine wasn"t that way. The peice of welding wire went right thru on mine.....HTH Tim
Dell (WA)
03-19-2007 20:32:04
John..... ..dang, I told you, you can't gitt there from here.
The gastank vent is on the slanted front side of the 4"-dia dome that you can barely see looking forward from your flip-up battery door. Iff'n you had "X-ray" vision, looking down thru the hood, it would be about 10 o'clock on the dome, and the gasdoor is at 6 o'clock. Its about 1/4" hole and very popular as a nesting place for mudd-dobbers. (and other feisty beasties)
As I said, the original gascap was NON-vented because? the gastank already had a "splash-proof" vent. But iff'n you don't VENT yer tank, yer gravity feed gas system will hydraulically vacuum-lock and yer carb will DIE of starvation. EPA, OSHA, and other gov't bureaucrats didn't like Ford's 1939 design and so Ford actually did a "free" gascap recall in the 80's? I don't know iff'n it is still "active". ?Quen Sabie? ..... ..Dell
A. Bohemian
03-20-2007 08:18:26
 Ford Wasn't Alone! in reply to Dell (WA), 03-19-2007 20:32:04
Dell: I bought a reprint of the Super C Farmall Operator's Manual when I bought my Farmall from Dad. We never found the original, not even in 1994 when we moved my grandmother out of the house she and Grandpa were living in when he bought the tractor new some fifty years earlier.
It has a warning inside the front cover about operating the tractor with the original cap, and an offer of a free replacement cap.
No, I haven't checked with my Case dealer to see if they are still giving them away...
Bob
03-20-2007 13:23:50
 Re: Ford Wasn't Alone! in reply to A. Bohemian, 03-20-2007 08:18:26
Yes; they are still giving away the IH gas caps; for about another year I think. If (A final date has been announced but I don't know it; offhand.)
Navisitar is actually the company doing it; rather than CNH.
You'll have to paste this into your browser as this site does NOT allow it to be posted as a link.
http://www.cleancomputes.com/Cub/Free%20Gas%20Cap.jpg
JEF LEF
03-20-2007 04:03:09
 Re: dell you might have hit something gas tank . in reply to Dell (WA), 03-19-2007 20:32:04
Speaking of gas tank vents, I enclosed my engine because I was getting too much moisture in the crankcase. I was using it all day last Saturday skidding logs. When I shut it down it was venting quite a bit of pressure and the gas tank was warm to the touch. I'm think-in the gas may have gotten a little too warm. I have a new radiator and thermostat and I always cover the grill in cold weather, but it wasn't running a warm enough temperature too keep the condensation out of the crankcase. I'll have to think of something else to keep the crankcase warm, maybe insulate it.
