Hydraulic pump base
Old George
06-04-2001 21:15:42
Oh the agony of setback! Found a small crack in the pump base from the test port plug about 1" long. Do you think JBweld is worth a try here or should I just try and find a new/replacement base? I sure don't want a leak there to mess up the new paint. Thanks in advance!
Alan Esch
45 2N kit 183513
ZANE
06-05-2001 08:30:37
 Re: hydraulic pump base in reply to Old George, 06-04-2001 21:15:42
If it is cracked there it can be fixed by Heliarching it. Any modern welding shop should be able to fix it.
JB Weld will not withstand 2000 pounds of hydraulic pressure.
Zane-Does it matter if it's cast iron or aluminum?
06-05-2001 21:35:59
 Re: Re: hydraulic pump base in reply to ZANE, 06-05-2001 08:30:37
Mine is cast iron. Thanks for your advice sir!
Timk
06-04-2001 21:23:56
Unless you are using the test port for some remote hydraulic set-up, I would think that JB Weld would do the trick. I don't know the exact location of the termination of the crack, but if you drill a small hole right at the end of the crack you will stop it from cracking further. I would definately try to fix it. My $.02
