Over-run Coupling Question
A. Bohemian
03-21-2007 14:07:17
On a neighbor's tractor, if I grab the shaft on the over-run coupler, I can wobble it with my hand! It moves about 3/8 inch.
Surely, this isn't normal. Or is it? I'm not familiar with these.
(I know, safety. I automatically flick the PTO out of gear whenever I push in the clutch on any tractor I operate. This allows the tractor to stop quickly when necessary and absolutely prevents my getting off the tractor with the PTO engaged. Not as foolproof as an over-run coupler, but still effective.)
Assuming it can't be repaired, what's a replacement run these days?
soundguy
03-21-2007 18:24:49
 Re: Over-run Coupling Question in reply to A. Bohemian, 03-21-2007 14:07:17
My new speeco one has about 1/4" wobble in it. I'd check that one to make sure it is lubed.. it meay be wearing out prematurely. Also.. I have seen some people put a 1 3/8 ORC onto the oem 1 1/8 shat by rigging it with a pin.. and the pin is the only thing coupling th orc tot he pto.. and it wobbled ALOT!
Soundguy
Dave 2N
03-21-2007 16:52:02
That seems to be quite normal for the ones I have.
JoePilot
03-21-2007 15:32:09
You may want to take off the grease fittings and make sure the pin is still in place. If so, it shouldn't be a problem.
A new ORC runs about $40. The are available on this site, Agrisupply, etc.
Joe
old
03-21-2007 14:35:27
Most of the ones I have also have a lot of free play in them. I think its pretty much normal for them. Plus I also think that if its working as it should then why fix it. You know the old say if it isn't broke don't fix it. LOL
