Order Ford 9N Parts Online
9n
brm
03-21-2007 16:32:33
ihave a 41 9n all aluminum dash serial#30411
i want to convert to 12v can i put 12v points in my 6v dist and then go from there?
Bruce (VA)
03-21-2007 18:41:39
 Re: 9n in reply to brm, 03-21-2007 16:32:33
There is a nice writeup under 'Articles' (on the left) with good advice on converting an N to 12v. The real question, however, is why you would want to do that. From my experience, I've only found two reasons to convert an N to 12v: If you need to run 12v equipment (sprayers, pumps, lights, etc) or you N has poor compression (like a lot less than 90 lbs) and you do not want to rebuild it, then a 12v conversion makes sense. Otherwise, you will likely be trading one set of problems for another. If your N is hard to start in cold weather (or any weather) find out why & fix it! These tractors have low compression, low HP engines and will start just fine on 6v. There is nothing inherently 'wrong' w/ a 12v conversion. The problem is that there are about 6 different ways to convert the tractor to 12v, all of them work, and an infinite number of ways to do it wrong. It's like this..... if you have a basic understanding of tractor mechanics, you can buy a quality kit & do it correctly. But, and here is the #1 issue: the first time you have an electrical problem, you are going to have to explain to everyone trying to help exactly how your tractor is wired & what exact parts you used. The owner of one of the local small tractor repair/parts shops around here refuses to work on electrical problems on 12v conversion tractors that he did not convert himself. As he explained to me, at $50 per hour, tractor owners get mighty hot when they get a $100 bill just for him to find the problem. Most problems we read about w/ 12v conversions are as a result of folks getting in over their heads or buying tractors w/ "Bubba" conversions, and now the new owner is stuck with trying to figure it out. Now, having said all of these good things about 12v conversions, I must declare, for the record, all three of my N's are 6v & they all three start the first time, every time, no matter what the weather. You will find that to be the case with folks who live in a lot of places much colder than VA.
old
03-21-2007 18:25:42
A set of points are a set of points. Doesn't matter if its 6 volts or 12 volts the points are the same. Now the coil can be differant and if you keep the 6 volt coil you have to do as Bob says
Bob
03-21-2007 17:22:34
If this question IS for real...
You need to add a "converting resistor" of 1.8 Ohms or so ahead of the original coil or switch to a "12-Volt" coil.
Dunk
03-21-2007 16:50:25
Just out of curiosity, can you tell me the difference between 12 volt points, and 6 volt points?
Lance in Brenham, TX
03-21-2007 17:13:21
 Re: 9n in reply to Dunk, 03-21-2007 16:50:25
about 6 volts - I couldn't resist
Dunk
03-21-2007 17:17:12
 Re: 9n in reply to Lance in Brenham, TX, 03-21-2007 17:13:21
Yes, I had already thought about that one, Lance..(Good call though)
But do the 12 volt ones cost him twice as much?
roger '40 9n
03-22-2007 06:28:23
 Re: 9n in reply to Dunk, 03-21-2007 17:17:12
"But do the 12 volt ones cost him twice as much?"
Actually they should cost half as much since they have half the current going through them.
Roger in Michigan
03-21-2007 19:42:53
I would be shocked if they did - get it, shocked?
Curley
03-21-2007 17:03:57
Typical sarcastic reply from dunk. Yes you can, there is no difference .
Dunk
03-21-2007 17:07:56
 Re: 9n in reply to Curley, 03-21-2007 17:03:57
Does he not already have 12 volt points in his distributor, Curley?
Dunk
03-21-2007 17:15:24
 Re: 9n in reply to Dunk, 03-21-2007 17:07:56
There could be thangs that I don't know about.
There could also be a salesman trying to rip him off.
I would like to get to the bottom of that.
Curley
03-21-2007 17:33:14
 Re: 9n in reply to Dunk, 03-21-2007 17:15:24
Dunk, you talk a lot but dont say anything. But you do send fine people to other boards.
Dunk
03-21-2007 17:39:21
 Re: 9n in reply to Curley, 03-21-2007 17:33:14
Will you be one?
Realtech
03-21-2007 18:10:33
 Re: 9n in reply to Dunk, 03-21-2007 17:39:21
How do you set 6 volt points compaired to 12 volt points. The same gap distance? And what about the timing, advance or retard? And would 6 volt points run hotter? Curious minds want to know..
Dell (WA)
03-21-2007 20:47:01
 Re: 9n in reply to Realtech, 03-21-2007 18:10:33
A Realtech would know those questions from AutoElectric 101.
Points gap is a function of coil design, engine operating rpms, and distributor cam profile. Has 'nuttin' to do with battery volts. Therefore 6 or 12-volts, points gap per mfr specs. I always set for max gap spec so as the rubbing block wears, guess what? I don't haffta re-set the points gap.
Ignition timing is a function of engine rpms and compression rating, gasoline octane, and camshaft specifications (timing) Has 'nuttin' to do with battery volts. Setter to mfr specs unless you have pre-ignition (pinging) which is a function of gasoline octane and engine compression.
Would 6-volt points run hotter? What do you think?..... ...respectfully, Dell, yer self-appointed sparkie-meister
03-21-2007 21:10:29
 Re: 9n in reply to Dell (WA), 03-21-2007 20:47:01
With my electronic ignition, I don't ever have to worry about resetting the gap 'cause the rubbing block wore down. hee hee
A. Bohemian
03-22-2007 14:20:03
 D'oh! in reply to Lance in Brenham, TX, 03-21-2007 21:10:29
This thread reminds me of the following dialog, from the episode of the Simpsons where Homer joins a traveling freak show with his act, getting hit in the stomach by a cannon ball:
FIRST TEENAGER: Oh, look, it's that cannon ball dude. HE'S cool.
SECOND TEENAGER: Dude, are you being sarcastic?
FIRST TEENAGER (downcast): I don't know, I can't even tell anymore...
