Questions For Old
RDAllison
03-22-2007 20:37:16
Can I Just turn the engine over and it will get all the tranny fluid out or do I need to wash it out some how?
I think some of the tranny fluid got into the exhaust system is that going to harm it?
old
03-23-2007 08:27:44
 Re: Questions For Old in reply to RDAllison, 03-22-2007 20:37:16
As Rusty says. Just pull the plugs out and spin it over good. It will make a mess but not hurt any thing by making the mess. Then just put the plugs back in and start it up. Ya it will smoke for a minute or 2 but thats ok since it will clear up fast. It will also burn out of the exhaust as it runs which is also ok. Oh one more thing don't stand behind it or have it sitting some place that the tranny fluid from the exhaust will be hurt by the tranny fluid spraying out of the exhaust. Or in other words don't park it so your wifes car is right behind it or you might be in the dog house a day or 3 LOL
RustyFarmall
03-23-2007 05:49:54
Crank the engine over several revolutions with the spark plugs removed, and then you should be good to go. It will smoke quite heavily for a few seconds, and then should clear up.
john hunt
03-22-2007 20:53:13
it's burn up oil, you might use some wd40 as starter fuild ,to get stared it.. will smoke it and it going to smoke. get it running and clear up in few minute and should run fine good luck
RDAllison
03-22-2007 20:40:29
sorry, I forgot to say thank you vary much for your help.
