This may sound simplistic, but it is what I setup at work. It was easy.. used no special software.. and -any monkey- at work can set down and update the entries. I made a folder on my desktop titled equip maint Int hat folder, I made a another folder for each piece of equip we own. Inside each of those folder is 3 text files. The first file has the machines sn, date and any unit codes i need, plus a list of all the filter numbers and any specialty oils, etc that it takes. 2nd file is 'parts' 3rd file is maint. In the parts file, I make an entry for each part I buy for that machine, as follows part price where purchase/instaled hours headlamp 5$ TSC 3-1-07 /3-10-07 720 as an example.. In the main section, I make a line item for each time i do maint on the machine date, hours, maint performed 3-1-07 720 greased all zerks etc. Those 3 files just keep running... a new line for each entry.. and you have a top to bottom list of all parts bought and when they were installed ( warranty? ) and where you got them... notepad or wordpad with windows is all you need to do this... With a couple clicks you can bring up the machine info file when you need to order filters.. or you can open the part file and see the date you purchased a part to check on warranty.. ect. You can opent he maint file and see when your last lube or filter change was.. etc. Soundguy
