What's this lever for?
RodneyinNY
03-23-2007 18:04:34
Just unloaded into the driveway a 49 8N that I purchased over the past three weeks. I just noticed a lever about 7-8 inches long with knob on end situated on a round plate to the leftside and a little behind the seat (close to where the left brake locking mechanism is) and I have no idea what it is for. Still have yet to get familiar with the whole tractor and purchase the manuals I'll be needing for it. Thanks ahead for any answers and hope to learn much from everyone
RodneyinNY
03-25-2007 17:02:25
 Re: What's this lever for? in reply to RodneyinNY, 03-23-2007 18:04:34
Thanks everyone for your help. Today I finally had a chance after church and between skimmimg boiling sap to check out what everyone said. Sure enough, with lever in the rear position PTO is engaged and hydraulics work, with it forward the PTO is disengaged and so are hydraulics. Yes ordering manual asap. Loved the four wheel drive line, if only.
john hunt
03-24-2007 07:01:27
third party image
if this what you talkin about. if not you have you have a go slow trany look at gig fo11 and if that what you have YOU GOT PTO
john hunt
03-24-2007 06:33:16
you want me guess too.. i don't think so. I would think it would be better see a picture of what he talking about ...
roger '40 9n
03-23-2007 18:49:01
That is the PTO engage lever. Push it back to engage the PTO.
You need your PTO running to use the hydraulic lift 'cause the PTO shaft runs the pump.
The other little lever on the right side (starboard) under the seat is the Draft/position control switch. Forward for ground engaging impliments (eg. plowing) up for fixed position pulling -- brush hog, trailer etc.
Roger in Michigan.
PTO
03-23-2007 18:19:04
Mash the clutch pedal, push the lever forward, and it will engage the PTO. Mash the clutch pedal, pull the lever back, and it it will disengage the PTO. Might be the other way 'round. Mine stays engaged all the time so's I can use the lift so's I really don't remember which way is which, but that is what it is for. Don't have much call to use the PTO. If there is a cover on the PTO, take it off so as you can see which way to it works. Sure as shootin' somebody will tell you the correct way to make it work. The one under the seat on the other side is a little beyond my comprehension right now, although I know what it is for and how it works .
DON TX
03-23-2007 19:23:16
 Re: What's this lever for? in reply to PTO, 03-23-2007 18:19:04
Vica-versa...forward is off, back is engage PTO. The lever under the seat/right is the position control lever. Up is disengaged..down is engaged. HTH
DON TX
PTO
03-23-2007 19:49:02
 I remember now that you mention it... in reply to DON TX, 03-23-2007 19:23:16
Thanx, DON TX, couldn't remember which was which. Been along time since I have had any reason to use it.
Dunk
03-23-2007 18:12:22
That's the 4 wheel drive!!
Just kiddin big time!!!
I think you may find some good info on that on John Smith's Page it may be a Howard!!
You may have won the prize today.
Dunk
03-23-2007 18:14:55
 Re: What's this lever for? in reply to Dunk, 03-23-2007 18:12:22
OMG, OK, I am off my rocker!!
He did say left side!! (my other dang left!!, and that is my favored hand)
I'm outa here, I hope!!, been a rough week, and still got Saturday and Sunday to go...
Hobo,NC
03-23-2007 19:44:02
 Re: What's this lever for? in reply to Dunk, 03-23-2007 18:14:55
Off to Norfolk Va 'bout 7 in the morring gonna ride shot gun and see how many N's i kin spot, Road trip
Dunk
03-23-2007 19:48:00
 Re: What's this lever for? in reply to Hobo,NC, 03-23-2007 19:44:02
Just be careful and bring my friend back home safely.
There are IDIOTS on them roads.
Sean (TX)
03-23-2007 18:32:40
 Ill drink to that :) in reply to Dunk, 03-23-2007 18:14:55
Ill drink to a rough week too!! Cheers...
Dunk
03-23-2007 18:34:42
 Re: Ill drink to that :) in reply to Sean (TX), 03-23-2007 18:32:40
Sean (TX)
03-23-2007 18:45:53
 Re: Ill drink to that :) in reply to Dunk, 03-23-2007 18:34:42
third party image third party image third party image third party image third party image third party imagethird party image third party image third party image third party image third party imagethird party image third party image
Dan
03-23-2007 18:14:47
A Howard aux. transmission slector is on the right side isn't it?
Dan
Dan
03-23-2007 18:09:18
Congrats on the purchase. This is the PTO selector. I HIGHLY suggest you obtain an 8N operators manual - thay are a tad over $10 for the re-printed ones and comes with a wealth of info.
Good luck,
Dan
