hydraulics question
RP-40-9n
03-23-2007 21:25:45
i was lifting a pretty heavy load and the lift started a very loud squeal, like a dry bearing fixin to lock up, but really loud . then it quit lifting, dropped down a little and bounced up and down. then would not lift at all, unless i drop the rpm down then it lifts good. seems lower rpm would be less likely to work. am i lookin at a rebuild? thanks RP
Tex - Driftwood
03-24-2007 20:13:50
 Re: hydraulics question in reply to RP-40-9n, 03-23-2007 21:25:45
RP, let me know if i can help.
soundguy
03-23-2007 22:29:54
Loud squeals from heavilly loaded HYD system generally mean a relief is opening.
Perhaps your relief opened and got crud in it and is no partially open.. or worse yet.. it has been damaged and is opening too soon.
I'd pull the inspec cover and lift it under load and see if there is alot of oil wash behind the pump.
They are cheap.. less than 30 to repalce. and CAN be done without dropping the pump or pulling the pto shaft.. but you need monkey arms and a bent wrench to do it without pulling the pto shaft. if you do pull the pto shaft.. it's not too bad.. etc.
The visual inspection of the sump is ALWAYS the best place to start looking when you have a hyds problem.
Soundguy
RP-40-9n
03-24-2007 08:03:02
 Re: hydraulics question in reply to soundguy, 03-23-2007 22:29:54
thanks s g would i need to leave the oil level where it is to make the visual check, as i have never looked inside it before. thanks again RP
Sean (TX)
03-24-2007 09:34:49
 Re: hydraulics question in reply to RP-40-9n, 03-24-2007 08:03:02
You have to have the oil at the normal level for the visual check.
soundguy
03-23-2007 22:13:06
Can we assume this is a 9n?
har to diagnose otherwise?
Soundguy
RP-40-9n
03-23-2007 22:18:40
 Re: hydraulics question in reply to soundguy, 03-23-2007 22:13:06
yes its 9n sorry for the confusion. RP
