Aron..... ..yer mom is doin' ya a good deal. Learnin' tractorin' mechanicin' is good fer the sole and makes mommy proud. First-off gitt an I&T FO-4 manual $25, (cheap) readily available at sponsors of this great N-Board, most agricultural emporiums, Borders Books, Amazon.com; www.n-news.com has great archive of 3-point implement manuals. Your local CNH (ex-Ford) dealer evens sells it, isn't that amazing? Even my local John Deere (byte my tongue) parts counter is selling it. Gittcha one and read-itt. Your 8N tractor ain't that heavy, it only weights 2460lbs (without driver) per N-Ford Owners manual. How fast should it stop? Welp I can SKID the tires on my 8N. Having big clod-hoppers and the brakes adjusted is partly why and having UN-GREASY brakeshoes is 'nutter' reason. The 8N-brakes are adjusted by "spoon", (kinda bent screwdriver blade) ask an automotive parts counter person to show you one. You can use a short-handled screwdriver instead. The brakeshoe adjuster is a "star-wheel" accessable thru back of brakedrum slot. While yer at the autoparts store, gitt'cha 2-spraycans of brake-cleaner. ($10, cheap) squirt the straw thru the back of the brake adjuster slot and WASH yer brakeshoes by swinging yer jacked-up rearwheel roundy-roundy. It'll drain out the drum gap. Use it ALL for just one brake. This will generally fixx yer greesy brakes problem and beats replacing seals and shoes. Remember, greezy brakes are usually caused by OVERFILLED hydro-tranny oil. pull the dipstick plate bolt at 6-o'clock and let any overfill drain down the side of the tranny overnite. tip: you haffta jack-up yer rear diffy so you can adjust yer brake shoes. You adjust the star-wheel until swinging yer wheel stops from brake shoe tightness. simple, eh? Each rearbrake has individual parking brake pawls. thats them flippy-things that fit in the notches behind yer heels. Stomp down on brake pedal and flippy the pawl into a notch. Simple, eh?..... ..HTH, Dell
