2n 3 point hitch
4 bottem
03-27-2007 04:53:55
Has anybody ever fixed a 3 point that drops by rehoning the cylinder and usind the oring piston set up. The piston and rings show some scoring. but the ring gaps are very tight. I dont think the problem lies in the valving but im going to remove and clean Thanks ED
souNdguy
03-27-2007 05:21:14
 Re: 2n 3 point hitch in reply to 4 bottem, 03-27-2007 04:53:55
Most of us have been into our hyds and done this repair. Also.. as hobo said.. replace the safety valve too.. it takes an additional 1 minute when the pump is out, and is worth the 28$ to not have to drop the pump 1 week later and repalce it once you get the lift nice and strong again and then blow out the old worn relief valve..
soundguy
Hobo,NC
03-27-2007 05:15:06
Sure, also replace the safety relief valve at this time its money will spent.
