Low RPM's
Premie-farmer
03-27-2007 08:56:25
I have lower RPM's full throttle gets me 1800 RPMs usually get over 2000. I thought it was related to dirty fuel since I had ran out of gas in the middle of driveway and of course the gas can was empty so I ran to the country store 4 miles away and bought some and splashed it in the tank but when I started the old girl didn't run as fast as she had previous to the OOF condition on way back to shed. I checked the sediment bowel and the two screens there were clear. Took the elbow off the carb and there was no screen there.
Shall I pull the carb and just clean and rebuild or could there be something else?
premie-farmer
03-27-2007 09:23:11
 Re: Low RPM's in reply to Premie-farmer, 03-27-2007 08:56:25
I have a full stream of fuel flowing from the line at the carb when disconnected. I'll check the bowl drain though thanks.
LeeMo
03-27-2007 09:17:56
You might try blowing air back through the fuel line from the carb end in case there's an obstruction in the tank and/or check for a solid stream of fuel at the plug in the bottom of the carb.
LeeMo
03-27-2007 09:14:14
Yes.
