ONE possibility
A. Bohemian
03-28-2007 13:59:34
Are you sure you are hearing pre-ignition noise and not valve clatter?
One often starts to hear lifters complaining as the car approaches 100k miles. If the lifter is not working properly, it is possible that a valve is not closing completely, which allows oil to leak into the combustion chamber from above.
If the leak is slow enough (and they usually are) one sees a little puff of oil smoke at start up, which disappears after the oil burns off.
Check your plugs to see if one looks oily or carbon-fouled.
