Jason McL hydralics
richmond in
03-28-2007 17:58:40
I didnt see any fluid coming down from the top. i even took the top cover off and checked it out. tube looked ok and everything under the cover did to. for some reason im just not getting fliud from the pump. its not even reaching the tube. i started the tractor and took the bolt out in the front right corner of the pump and still no fluid came out. that is the bolt i took out to get the lift to lower to begin with. does fluid actually goe through the safety valve. i thinking it may be cloged or something like that in the pump. however thanks for your help
JD Ga
03-28-2007 19:18:40
 Re: Jason McL hydralics in reply to richmond in, 03-28-2007 17:58:40
When you took the pump out for cleaning did you actually take the pump apart and clean it to? I'll bet if the sump was full of trash the inside of the pump has some in it to. The outlet & inlet valves inside the pump may be partially clogged. Was the control valve moving freely? You may also want to try to clean the saftey & intake valves w/ compressed air. But you may have to purchase new ones.If you take it apart you'll have to have new gaskets. If this does'nt fix it ,it sure wont hurt it none.
