Voltage Regulator question
Pooh Bear
03-28-2007 19:54:55
Early 1949 8N, converted to 12 volt.
I have been having a problem lately keeping the battery charged. I turn the key on and the charge light comes on. I start the motor and the charge light goes out, as it should in normal operation.
But, after running a while the battery gets weak. Eventually it won't restart the engine unless I jump start it or put a charger on the battery for a few hours.
I will be checking all the connections for "clean, tight, and bright." I did do a recent tuneup. But other than that I haven't touched the electrical system.
My dad suggested I check the voltage regulator. How can I tell if I have an internal or external voltage regulator.
My way of testing an alternator has always been to start the engine and disconnect the battery and see if the engine keeps running. If not, the alternator is bad. I have recently learned that this is bad for the alternator. And it won't detect a weak alternator.
So where do I start.
Thanks.
Pooh Bear
soundguy
03-29-2007 22:08:49
 Re: Voltage Regulator question in reply to Pooh Bear, 03-28-2007 19:54:55
I'd like to add that testing an alternator by pulling a bat cable is really brutal tot he alternator!
Soundguy
Dell (WA)
03-28-2007 20:10:03
Pooh..... .would you believe that the commonly used Delco 10-SI alternator has BUILT-IN solid state voltage regulator?
Me? Iff'n I was suspect alternator problems, I carry the alternator into enny automobile parts store for a "FREE" test.
But based upon yer stated "having to recharge" the battery. I'd suspect yer BATTERY is DYING. I'd carry it into the same autoparts store for a "FREE" battery check. Batterys don't live forever in tractor service..... ..Dell
A. Bohemian
03-29-2007 08:19:42
 Re: Voltage Regulator question in reply to Dell (WA), 03-28-2007 20:10:03
I'm with Dell. I've quite often encountered problems similar to the one you describe over the years. If the idiot lights are working normally, the battery is usually at fault.
Since you already know how to use a VOM, here's a simple test that is not foolproof, but has never yet failed me.
Start the motor, and connect the VOM right at the battery terminals to read voltage. Let the meter settle to a steady reading. If it won't settle, you've already determined the regulator is probably bad.
Usually they do settle down, though, even with a bad regulator. Now, turn the lights on and off, rev the motor a little, and anything else you can think of to vary current flow within acceptable parameters.
Voltage hold steady or only vary slighlty? Regulator probably good. Voltage vary wildly? Regulator probably bad.
This is one of the reasons I always prefer a guage package on my vehicles; you can often troubleshoot from the driver's seat without dismantling a thing. With a little luck, you can also see trouble developing long before the idiot light comes on.
I've been reluctant to take my alternators to an auto parts store ever since the teenage girl who was helping me managed to blow one up on the stand. She wasn't hurt, thank God, and I got a free alternator out of the incident, but still...
Pooh Bear
03-28-2007 20:31:27
I have always loved the Delco 10SI alternator. The one I have looks like a 10SI, but how can I be sure. I remember some of the older Ford alternators looked like the 10SI but used an external VR.
I'm replacing the battery anyway.
I borrowed this battery 2 years ago from my Dad.
He wants it back for his trolling motor.
He said by Monday I have to get a new battery.
I'd like to upgrade my alternator to a 60+ amp model. Right now the only thing I run is the ignition system of the tractor. I don't have working headlights or other electrical stuff. But sometimes when I try to run my power inverter off the tractor the alternator can't keep up.
I thought the system could be tested without taking anything apart, using a VOM.
With the tractor off, a fully charged battery should read 12 to 12.5 volts. With the tractor running the voltage should read 14 to 16 volts. Am I right about this (or even close).
Thanks.
Pooh Bear
dan hill
03-29-2007 02:40:46
 Re: Voltage Regulator question in reply to Pooh Bear, 03-28-2007 20:31:27
You can check a battery with a 90 cent hydrometer.Uneven readings cell to cell means the battery is getting tired.Sealed batteries cant be checked with a hydrometer.I wont buy a sealed battery.An alternator will attract a screw driver when it is charging.I use an induction ammeter to check actual charge rates.No connections needed, just lay the output wire in the groove on the back of the meter.My truck battery has a May 01 date on it and is starting the truck with ease. but hydrometer readings are uneven with 2 cells reading half charge a day after Ive used the truck.
Bob
03-28-2007 21:58:07
third party image
Pooh;
You're "right on" with your expected voltage readings.
Check the voltage right at the battery POSTS to rule out a poor connection somewhere keeping the full charging voltage of the alternator from reaching the battery.
Look at the photo of a 10SI; and compare it to what you have...
On most; the Delco Remy logo will be visible as seen on the lower area of endbell in the photo; but some have been rebuilt with generic "endbells" without the trademark on them.
Hobo,NC
03-29-2007 05:54:28
 Re: Voltage Regulator question in reply to Bob, 03-28-2007 21:58:07
Woops did not mean fer that to b a reply to you, ment fer pooh
Hobo,NC
03-29-2007 04:32:28
Their izz a test hole on a 10SI to check the voltage regulator and the ability of the alt to perform at peak out put. Its a D hole at the back of the alt, you insert a screwdriver in it and touch a metal tab to ground out a brush and bypass the regulator. B careful you kin damage the alt if you insert the screwdriver to far. Bout all rebuilt 10SI's are 60 amp rated. I spec you would never need more than 30 amps or ever B able to spin the alt fast enuff on a N to produce 60 if you had a 60 amp alt. Like Dan posted you kin touch the rear bearing wif a screwdriver to confirm that it izz charging but even still it does not tell ya if its charging like its spose to only its izz try'n to.
Pooh Bear
03-28-2007 22:22:16
Thanks for confirming the voltage readings. I'll borrow a VOM tomorrow from my brother and check it out. And I'll take a close look at the alternator to see if I can identify it.
That picture is the first time I have seen the main output wire being fed back into the VR. Usually that function is done internally (for the ones I have taken apart).
Thanks.
Pooh Bear
Bob
03-28-2007 22:50:05
 Re: Voltage Regulator question in reply to Pooh Bear, 03-28-2007 22:22:16
That jumper wire is the "voltage sense" line from the alternator's output stud back to the #2 "voltage sense" terminal on the alternator's internal voltage regulator.
For even more accurate voltage control AT THE BATTERY the lead from the regulator's #2 terminal can be connected as close to the battery's (plus) terminal as possible... to the battery cable stud on the starter solenoid for example. Our tractors can get along just fine with the jumper at the alternator; vehicles with more complicated electronics use "remote voltage sensing".
Not that it is a BAD thing for our old tractors; either! I have set up some of my alternator conversions over the years with "remote voltage sensing".
For more information on remote voltage sensing; as well as "one-wire" vs. "three-wire" alternators; punch up the link below.
A. Bohemian
03-29-2007 11:10:29
 Great link, Bob. in reply to Bob, 03-28-2007 22:50:05
Thanks.
After reading the info on battery charging, I think I'll remove the batteries from my vehicles when using an external charger in the future.
