Transmission locked in Gear
Refbb
03-29-2007 07:43:34
How do I go about getting gears moved back to neutral position and which gear or gears will I need to move.
Dell (WA)
03-29-2007 19:26:16
 Re: Transmission locked in Gear in reply to Refbb, 03-29-2007 07:43:34
Refbb..... ....Do the eazy stuff first. JACK-UP yer tractor so the TRANNY NO-LOAD. Clod-hoppers plunked down on the clutch petal. NOW try an wiggle yer tranny shifter outta gear.
Iff'n that don't work, gitt back to us with the secret tranny code. (3-speed or 4-speed) ..... ..Dell
Refbb
03-30-2007 06:50:54
 Re: Transmission locked in Gear in reply to Dell (WA), 03-29-2007 19:26:16
I have already taken top off trans and its a 4 speed
Dell (WA)
03-31-2007 09:38:48
 Re: Transmission locked in Gear in reply to Refbb, 03-30-2007 06:50:54
Refbb..... .Would it surprize you to learn that the ALL the sliding gears MUST be slid to the "GAP" between the gears of the counter-shaft cluster to be in NEUTRAL???
You MUST JACK-UP yer tractor diffy to take the "pressure-off" BEFORE you try to slide yer gears on the main shaft. When you looky-look down, just use LARGE screwdriver/lever to slide any and all gears into the "gaps". Simple, eh?
Unfortunately, my eyeballs can't see yer tranny gears, but yours do. Iff'n you still have tranny problems, start a new post..... ....respectfully, Dell
old9
03-29-2007 16:28:25
This happened to me last year on my 53 NAA. 4 speed ,, second gear broke. Loose tooth jammed between gears. Real Bad day!!
What tractor do you have? It does make a LOT of difference.
A. Bohemian
03-29-2007 17:30:58
 I'll BET it Was Bad! in reply to old9, 03-29-2007 16:28:25
I've never talked to anyone who encountered this problem before. What did you do?
