Exhaust Repair
R.M. In AL.
03-31-2007 12:20:55
Hey guys I have a rear exhaust leak around the manifold.I replaced the gasket about five years ago and noticed some damage to the block and now I gonna repair it.I know JB weld is good but I am wondering with all the industrial repair products is there one you think is better.Also will the products like JB Weld last long under this type of heat.Thanks guys. R.M. In AL.
bizkit
03-31-2007 13:31:30
 Re: Exhaust Repair in reply to R.M. In AL., 03-31-2007 12:20:55
we have doubled the gasket's on them thang's and got away with it done same thang on govener leaking oil fixed her up
Dell (WA)
03-31-2007 12:54:30
RM..... ..while J&B Weld is good stuff, theres better HI-TEMP stuff available out there. I'm not certain but I think there is a "hi-temp" J&B. Go Shoppin', you can read labels as well as I can.
You need to drill some shallow 1/8 holes to act like blind rivets. Clamp sumptin FLAT over J&B so you don't haffta pretend yer a milling machine. Piece'o'cake.
Tip: yer exhaust pipe to manifolt clamp BIG SIDE DOWN..... ....Dell
Bob
03-31-2007 12:53:44
"Furnace cement" sometimes lasts a long time when used to build up a damaged exhaust gasket surfaces. It is similar to the "goop" packed with "muffler bandage" kits.
