Order Ford 8N Parts Online
8N missing gears
Tom N MS
04-01-2007 05:36:22
I'm asking for a friend. From what I am told, it seems that 1st and second gears are not there but you can use 3rd and 4th. He was told that 1st was a problem so it was removed and as a result 2nd is lost as well..... Does this sound right? Now, assuming that nothing else is busted, how big a job is it to get 1st and second replacement gears in there? Thanks
john hunt
04-01-2007 08:49:34
 Re: 8N missing gears in reply to Tom N MS, 04-01-2007 05:36:22
dan did you ever have top off ever ..
DanL-Colorado-9N252085
04-01-2007 06:36:13
Something doesn't sound right about that. The tranny needs to come out and apart to put gears in; so why on earth would someone take the tranny out and apart just to take some bad gears OUT, yet reassemble the thing without 1st and 2nd??? I don't get it.
Take the top cover off. Maybe it's actually a problem with the shift mechanism rather than the gears themselves.
Tom N MS
04-01-2007 10:59:48
 Re: 8N missing gears in reply to DanL-Colorado-9N252085 , 04-01-2007 06:36:13
What does he need to look for once the cover is lifted? Thanks
Tom N MS
04-01-2007 08:05:40
Thanks for all responses. We'll pull the top cover first and try to see what is going on.
john hunt
04-01-2007 06:08:51
did you or him have the top of the transmission off ????
Tom N MS
04-01-2007 10:58:50
 Re: 8N missing gears in reply to john hunt , 04-01-2007 06:08:51
He just got the tractor. It was his Grandfather's tractor so he knows nothing about what has been done, just what he is told.But since he has had it(2months) he has not had the tranny cover off. What does he need to look for once the cover is off? Thanks
ZANE
04-01-2007 06:07:06
Every bolt from the clutch housing to the differential housing mating surface must be removed to put a gear in or out of the 8N transmission. Lots of bolts!
Zane
A. Bohemian
04-01-2007 06:38:56
 By the way, Zane... in reply to ZANE, 04-01-2007 06:07:06
...what happened with that Saturn?
ZANE
04-02-2007 05:32:45
 Re: By the way, Zane... in reply to A. Bohemian, 04-01-2007 06:38:56
It is running better but sputters some at low throttle and at part throttle cruising. With a little more throttle it smooths out OK and is not running too rich now??? Don't know why??? May not have been the problem to begin with???? May have been the throttle position sensor???? It had a very loose connector and I put a wire tie on it to hold it on. Those connectors and wire should have been used on tinker toys! I have it sitting in the front yard by the highway for sale. Looks good. Got any suckers you can send me??? I give kick backs! :O)
Zane
