Order Ford 8N Parts Online
8N rear axle trumpets
Pooh Bear
04-01-2007 17:03:47
Are the newer double seal rear axle trumpets able to be swapped out for the older single seal rear axle trumpets? What would it take to do so.
Just curious.
Pooh Bear
Dell (WA)
04-02-2007 07:44:06
 Re: 8N rear axle trumpets in reply to Pooh Bear, 04-01-2007 17:03:47
Hey Pooh..... ..remember Hakeems Razar. New rear axle seals $20 (cheap) USED trumpets $200. NEW rearaxle shaft $150. NEW bearings $50.
More better you replace the seal-killing tapered splined rear HUB $50..... ...Dell
Pooh Bear
04-02-2007 10:30:31
 Re: 8N rear axle trumpets in reply to Dell (WA), 04-02-2007 07:44:06
As usual you are right Dell.
I got fluff for brains. I'm allowed to think crazy things.
Pooh Bear
lonestarjeff
04-01-2007 17:43:37
Pooh...there was a post a few months back on this subject. You might try a search. One thing that stood out for me was the axle shaft has to be changed(or machined)along w/ the changing trumpets. The newer shafts have a machined surface for the outer seal to ride on.
Jeff
Pooh Bear
04-01-2007 18:53:06
 Re: 8N rear axle trumpets in reply to lonestarjeff, 04-01-2007 17:43:37
I remember a post about it quite a while back. I have bad luck when searching the archives. Probably be easier for me to just get a later model 8N with the double seals and just change out the whole rear end. That's a whole nother subject.
Thanks.
Pooh Bear
Hobo,NC
04-02-2007 04:45:21
 Re: 8N rear axle trumpets in reply to Pooh Bear, 04-01-2007 18:53:06
Pert neer shur the axles and trumpets izz all that's needed.
