Hand Crank
9N Chuck in Mo
06-06-2001 07:36:24
As I am taking the front end of my 9 apart, I notice a hole thru the grill, under the radiator and back to the crankshaft pulley. Looks like they designed this to be hand cranked if necessary. As I am only 40, I have never seen an engine started by hand cranking(except in pictures) Was this a common backup procedure and did the original tractors come with a hand crank as part of original equipment? Anyone started one this way?
Gaspump
06-06-2001 16:54:23
 Re: Hand Crank in reply to 9N Chuck in Mo, 06-06-2001 07:36:24
Yes the crank was one of the tool items that came with the N tractor.
Dave 50 8n
06-06-2001 12:32:43
I have a tractor calendar with a handcranked tractor on it. Inside the grill is what appears to be some kind of padded forearm guard that's stored there.
ZD
06-06-2001 11:22:53
The war years 2Ns were supposed to be cranked. I hear that they did not have a battery due to the war effort. I have not started mine with a crank, but do not wrap your thumb around the crank. lay it alongside of your index finger and cup your hand loosely(!) around the handle. Then pull up in a swift motion and clear out. If it backfires it will break your wrist/forearm if it catches you. My uncle can testify to this, I know it by local legend.
Zeke Duge
z
9N Chuck in MO
06-06-2001 12:58:14
 Re: Re: Hand Crank in reply to ZD, 06-06-2001 11:22:53
Do you know if the crank tool ever stuck in the tractor after it started, or did they normally just fall out?
ZD
06-06-2001 13:46:36
 Re: Re: Re: Hand Crank in reply to 9N Chuck in MO, 06-06-2001 12:58:14
Never heard of it happening. (And that includes the Model A and the Model T) the attachment of the crank is a slip fit and the dogs that hold the spur which is on the side of the crank near the inserted end of the crank are tapered so that when the engine turns over the crank is thrown out by centripital (not centrifigual) force. (see, I did stay awake in High School) I lost the crank to the Model A 30 years ago when I lent it to my cousin so we cant try a cross-fit but it would be interesting...
Zeke
don t.-9n180179
06-06-2001 10:36:17
"My toy" has a front end (wagner) loader. This is where the hydralic pump is mounted.
JHill
06-06-2001 09:13:03
My neighbor had an N that he only used occasionaly so he hated to buy a new battery. He crank started his. Started with half a pull every time.
Box of Rocks
06-06-2001 08:48:16
Where would you get a hand crank?
Jim(MO)
06-06-2001 09:09:51
 Re: Re: Hand Crank in reply to Box of Rocks, 06-06-2001 08:48:16
Have seen them on eBay, listed for model T's and A's. Don't know if they fit the 'N or not. I think theres a good chance they do.
Don (NC)
06-06-2001 12:06:45
 Re: Re: Re: Hand Crank in reply to Jim(MO), 06-06-2001 09:09:51
When I asked that question several months ago, the consensus was that the N and auto cranks are different. I believe the N crank has a longer shaft and possibly a different fitting to engage the pulley.
Hank
06-06-2001 08:11:48
Started my 8N with the crank one whole summer when my ring gear was gone. Worked well.
Phil (VA)
06-06-2001 07:48:18
Yes, not on 9N, but have started some others that way. Also, useful mostly for things like turning engine for other reasons, such as setting point gap. If used for starting, pull up from bottom, don't push down, to avoid injury.
