Manifold Repair
R.M. In AL
04-02-2007 14:52:03
What size is the brass nuts that hold the manifold tight on an 8n.Are they standard or fine threads.Boy those things wont take much torque lol. R.M. In AL.
Dell (WA)
04-02-2007 19:04:28
 Re: Manifold Repair in reply to R.M. In AL, 04-02-2007 14:52:03
RM..... ..yep, brass-nuts are weaker'n stainless. (but not by much) Yer manifold BRASS-NUTS are size 7/16-20 (SAE fine-thread) And YES, yer brass-nuts are supposed to strip. Yer manifold studs are torqued to 40ft/lbs and BRASS-NUTS torqued to softer 27ft/lbs. This way, when you remove yer corroded brass-nuts, yer studs stay in the block and don't pee anti-freeze all over the place.
new BRASS-NUTS $.50c ea. Replace'em..... ..Dell
Bruce (VA)
04-02-2007 15:08:52
7/16-20x5/8 brass nuts, 27 lbs of torque. Use washers.
Jerrycpp(WA)
04-02-2007 14:55:36
5/16 SAE (fine thread.) You might also try Stainless Steel nuts. I've had to saw off the brass nuts - for some reason they shrunk onto the studs.
murn ga
04-02-2007 15:03:22
 Re: Manifold Repair in reply to Jerrycpp(WA), 04-02-2007 14:55:36
Jerry, was that a type o? The nuts are 7/16 sae
Jerrycpp(WA)
04-03-2007 08:02:27
 Re: Manifold Repair in reply to murn ga, 04-02-2007 15:03:22
Thank you! No, it wasn't a typo, it was a MIND-o. You're right - they are 7/16.
