oil pressure
Alex McCarty
04-03-2007 04:11:25
My 8n oil pressure guage will read o then 18, and back and forth on start up it's about 30 but after running for a while it will act like the guage doesn't work then will jump to 15 to 18 and stay there for a few minutes and back to 0. Anybody have any ideals?
dale t. reinhardt
04-04-2007 18:47:45
 Re: oil pressure in reply to Alex McCarty, 04-03-2007 04:11:25
Can anyone tell me what the square shaft on the back of my new oil pressure gauge is for . It turns but does not have any bearing on the reading on the gauge'
Drmeatman
04-03-2007 05:26:36
Alex,you could try another gauge.Also,have you taken the line off and cleaned it real well?
Alex Mccarty
04-03-2007 05:41:57
 Re: oil pressure in reply to Drmeatman, 04-03-2007 05:26:36
do you just take it off and soak it?
old
04-03-2007 08:27:03
 Re: oil pressure in reply to Alex Mccarty, 04-03-2007 05:41:57
Another way to clean the line out would be to take it loose then hit the starter button, don't turn on the ignition switch let it turn over long enough to get a goof flow of oil out the line. I might make a mess but it also makes sure you have a good clear line and that also keeps the dirt from going back in to the oil system of your engine.
souNdguy
04-03-2007 06:36:43
Blow air thru it.
soundguy
