A Few Thoughts
A. Bohemian
04-03-2007 12:07:37
(1) Re-check the gap on the plugs. Bad plugs often miss under load in my experience.
(2) When you pull the plugs, if one is fouled already you may have a compression problem. Engines with bad rings will often idle well and rev well but not pull a load. They will often run rough and be hard to start when other components are marginal, but start and run much better when the other components have been renewed.
(3) If you can find one, take the carb off a good running tractor and sub it out for yours. It doesn"t have to run perfectly, just make sure it can pull a load. If it does, the problem is not likely to be the carb.
ZoSo
04-03-2007 12:14:42
 Re: A Few Thoughts in reply to A. Bohemian, 04-03-2007 12:07:37
When i get home i will pull one of the plugs to see if it is filed or not. If it is i guess i move on to the compression test.
Drat!
04-03-2007 12:09:24
Obviously, I meant to say that if the tractor will NOT pull a load with the substitute carb, the problem is NOT likely to be the carb.
Sorry.
