coil keeps burning out
rcr2
04-06-2007 14:54:11
my coil keeps burning out ,it works for a couple of cranks and then theres no fire at the coil need help when it is firing theres a lot of spark at the plugs don't know where it could be shorting out
RP-40-9n
04-06-2007 17:30:40
 Re: coil keeps burning out in reply to rcr2, 04-06-2007 14:54:11
if its front mount, you might need to stretch the little pig tail at bottom of coil, to be sure its makeing contact. RP
old
04-06-2007 15:24:03
6 volts or 12 volts?? Front or side mount?? If its been changed to 12 volts your problem most likely is that its wired wrong and or doesn't have a ballast resistor in the system like it needs to have.
