lights
richmond in
04-08-2007 06:59:39
whats the best way to get your lights working with out having to run a ground wire to them. 48 ford 8n thanks
HCooke
04-08-2007 11:43:39
 Re: lights in reply to richmond in, 04-08-2007 06:59:39
I used star washers under the mounting bolt. Did not run a separate ground wire. Works well. I'm sure it depends on the jount between the hood and the doglegs.
Dell (WA)
04-08-2007 08:27:35
Rich..... .there is a very good reason for running separate ground wires for your INOP lites; its called RUSTY JOINTS. You don't wanna run a separate ground wire? Then take apart yer rusty jointed hood doglegs and clean the rusty seam. Then repaint the seam so it don't rust again. Then take apart yer rusty lite bucket and clean the rust. Then repaint yer lite bucket. Oh yeah, remember paint is an INSULATOR. Gitt the hint??? Run the ground wire. 6 or 12 volts don't matter, RUN THE GROUND WIRE..... .Dell
Sean (TX)
04-08-2007 16:47:27
 Re: lights in reply to Dell (WA), 04-08-2007 08:27:35
Dog legs are also grounded to where they bolt on down below. Not sure paint matters between the dog leg and the hood.
Sean (TX)
04-08-2007 07:02:37
I used dielecric silicone compound. Works great and no ground wire..
Sean (TX)
04-08-2007 12:17:56
 Re: lights in reply to Sean (TX), 04-08-2007 07:02:37
Dielectric
