Order Ford 9N Parts Online
1946 Ford 9N
RangerPaul
04-09-2007 16:05:36
I am thinking of buying one the "old greys" a 1946 Ford. The transmission/PTO is low on fluid. What type/viscosity should I use to refill? I gather it"s common to have rear axle leaks? I have not gotten it running yet. Anything specific to look at before trying to fire it up?
Thanks
Red weldinghood
04-09-2007 18:29:53
 Re: 1946 Ford 9N in reply to RangerPaul, 04-09-2007 16:05:36
90 weight oil for the rear end and pto unless you are in the north then you need 80 weight, and in the extreme north a 50 weight.
rear end axel leak =is common but they sell an after market kit called sure seal.
DanL-Colorado-9N252085
04-09-2007 18:00:36
What's your SN? Mine's a 46, too. I'm lucky; it came with the house and I haven't had to do anything to it other than change the rear oil and replace the PTO seal. Someone did a pretty nice job on it. Not a show queen but pretty nice looking and very reliable.
Ranger Paul
04-09-2007 19:03:08
 Re: 1946 Ford 9N in reply to DanL-Colorado-9N252085 , 04-09-2007 18:00:36
I think I need to get the SN off the machine. And check the other 'labels' if I can find any. This one hasn't been used in at least 5 years that I know of. My wife's boss got it with a 'ranch' he bought in Nevada and never used it.
Bob Harvey
04-09-2007 16:27:27
Check out the site, HUGE amounts of info and Data. P.S. You gots a 2N.
Bob Harvey
04-09-2007 16:30:00
 Re: 1946 Ford 9N in reply to Bob Harvey, 04-09-2007 16:27:27
Forgot to add, if you have established it's a '46, then it is a 2N....spend some time in "Research and Info" on the left.
Ranger Paul
04-09-2007 17:17:14
 Re: 1946 Ford 9N in reply to Bob Harvey, 04-09-2007 16:30:00
Thanks for the info. Looks like I have a place to start !!!
old
04-09-2007 17:43:22
 Re: 1946 Ford 9N in reply to Ranger Paul, 04-09-2007 17:17:14
I do this with all tractors that I have no idea how long its been since they have been started. I fill the cylinders with tranny fluid, that lubes the cylinders, cleans out rust and frees up the rings and valves. Then I would get an I-T FO-04 manual so you have an idea of whats is going on with it and how to work on it. I would also drain and replace ALL oils in it because theres likely to be water in them
