Timing Cover -Dumb question #673
9N Chuck in MO
06-06-2001 21:48:58
I ran out of daylight but am about ready to pull timing cover. Looks like I will have to pull alternator the way it has been mounted, and maybe the governor. I'm looking at the FO-4 manual and it doesn't say anything about this but, well here's dumb question #673, Do I need to drain the oil before I pull the timing cover? Thanks for your continued support!
rob 8N11071 KS
06-07-2001 08:24:15
 Re: Timing Cover -Dumb question #673 in reply to 9N Chuck in MO, 06-06-2001 21:48:58
You don't have to remove the governor, but you do have to back at least one bolt out most of the way.
Most of the oil should be in the pan.
Don't forget the front bolts under/behind the pulley.
Mikey
06-06-2001 22:52:38
Chuck,
Alternator? Yep. Governor, Nope. Oil? Only if you loosen the timing cover by removing the pan!
Mikey
9N Chuck in MO
06-07-2001 05:50:11
 Re: Re: Timing Cover -Dumb question #673 in reply to Mikey, 06-06-2001 22:52:38
Cool, kinda what I thought. Thanks.
