robshicla
04-14-2007 16:21:00
Could someone go to the "Help Identify" section under "Robert from Georgia" and tell me what this is. I think it is a resistor. It gets hot to the feel. It is located on the wire after the ignition switch and before the coil. (Front Mount Distributor) Thanks.
ZANE
04-14-2007 17:17:43
 Re: Help Identify in reply to robshicla, 04-14-2007 16:21:00
Resistors are supposed to get hot.
If the distributor still has the original six volt coil you should adjust the resistor to read about 3 volts at the top of the coil with the ignition points closed. Don't leave the ignition switch on for any length of time at any time to prevent damage to the coil and points. They don't like to be left with current on constantly.
Zane
robshicla
04-14-2007 17:21:29
 Re: Help Identify in reply to ZANE, 04-14-2007 17:17:43
I have a 12 Volt coil.
jmixigo
04-14-2007 17:02:42
Yessir, that is a resistor. Possibly adjustable, looks like one we used to use on heater fan motors.
Meewee
04-14-2007 16:39:29
third party image
There is your pic.
robshicla
04-14-2007 16:49:23
 Re: Help Identify in reply to Meewee, 04-14-2007 16:39:29
Thanks. I Did not now how to bring the picture over to the forum.
