Order Ford 8N Parts Online
resistor 1950 8N
robshicla
04-14-2007 17:17:16
I just put a resistor on today between the ignition switch and the coil. The metal wire inside the resistor turned red hot. Is this normal? This is a 12 volt system, 12 volt coil. Thanks.
Phil (NJ,AZ,Sask)
04-15-2007 04:20:02
 Re: resistor 1950 8N in reply to robshicla, 04-14-2007 17:17:16
Robshicla, The correct total "circuit" resistance for "ANY" front mount coil is 4.83 Ohms. The normal 12 volt coil has a resistance of 2.5 ohms which means you need ~ 2.33 ohms of additional resistance.
Singe Ignition resisters do not come that "large" (2.33 Ohms), 1.7 ohms is near Max
"Hobo" found that the OEM ballast Resistor followed by a 1.1 ohm Ignition Resistor worked reliably with the 12 volt 2.5 ohm Coil.
If you want to do it absolutely right you need to measure the total circuit resistance, but there is a twist, because the OEM ballast will measure 1.0 ohm "less" than its operating resistance. That means that if you use an OEM ballast the "measured" total resistance will be correct at ~3.83 ohms. (The Total Circuit resistance includes the points & Ignition Switch)
You will eventually burn out the coil if you operate it with more than 3 amps, your choice
Yes! you need the diode, it will protect the Alternator from loading damage. The diode trio, in the alternator, feeds the regulator circuit
"unloaded". If a diode (trio) shorts, from over loading, your ignition system & Alternator will go up in smoke.
JMHO
Dell (WA)
04-14-2007 17:48:24
 Re: resistor 1950 8N . . YES in reply to robshicla, 04-14-2007 17:17:16
Rob..... ...yes, not only burnie...burnie it also smokes. (oil from manufacturing process)
Nuttin' to worry about, that is normal, whether 6v or 12 volts..... ...Dell, yer selv-appointed sparkie-meister
Did you gitter to start?
robshicla
04-14-2007 18:00:52
 Re: resistor 1950 8N . . YES in reply to Dell (WA), 04-14-2007 17:48:24
No it did not start. But I think I found the problem. When I put new points and condensor in, I followed the Procedure in the I&T 8N manual for Timing. When you have the distributor on the bench, you take a straight edge to see if the points start to open 1/4 in. past the mounting hole. Mine was way off. I took distributor apart and found that a part of the rotating shaft (flat piece near mechanical weights) was cracked.
robshicla
04-14-2007 18:06:07
 Re: resistor 1950 8N . . YES in reply to robshicla, 04-14-2007 18:00:52
Question? What is a diode for? and how do I now if I need one. ( between ignition switch and alt.
Dell (WA)
04-14-2007 18:17:56
 Re: resistor 1950 8N . . YES in reply to robshicla, 04-14-2007 18:06:07
third party image
Rob..... . iff'n ya didn't need one, we wouldn't tell you to use one. Understand?
The diode or GM recommended idiot lite is so you can turn yer engine OFF.
The Delco 10-SI alternator internal gutts BACKFEED volts out to the ignition ON switch terminal which just also happens to be connected to yer ignition coil too. Guess what? Without the "isolation" of the diode (1-way switch) or 194 idiot-lite (power reducer) yer ignition coil will continue to gitt enuff power to run yer sparkies and you NEVER TURN ENGINE OFF!!! No matter what you do with yer ignition switch. Isn't that amazing? ..... ..Dell, a 12v advocate for the right reasons
Andy (MN)
04-15-2007 07:42:09
 Re: resistor 1950 8N . . YES in reply to Dell (WA), 04-14-2007 18:17:56
Hey Dell , Thanks for the information, I wondered what the diode was for and now I know.
robshicla
04-14-2007 18:26:03
Thanks for the info!
