Information, Please!
A. Bohemian
04-15-2007 08:58:54
Is the motor missing on one or more cylinders? Or, is there no detectable miss but a loss of power?
Or, are you saying when you rev the throttle you don't seem to get the correct response from the engine?
LoomismanOBX
04-15-2007 09:21:01
 Re: Information, Please! in reply to A. Bohemian, 04-15-2007 08:58:54
Hits on all cylinders but kind of a putting sound not smooth like it should be...
LoomismanOBX
04-15-2007 09:37:34
 Re: Information, Please! in reply to LoomismanOBX, 04-15-2007 09:21:01
...and it definately seems to have lost power too. Thanks...
Dell (WA)
04-15-2007 10:21:55
 Re: Information, Please! in reply to LoomismanOBX, 04-15-2007 09:37:34
Loomis..... ...yer description has all the indications of WEAK SPARKIES. Next to incorrectly set/worn ignition points (gap = 0.015 set on the kitchen table) according to Hakeem's Razer, its yer WEAK-SISTER ignition switch. $10 (cheap)..... ....Dell, yer self-appointed sparkie-meister
LoomismanOBX
04-15-2007 23:07:12
 Re: Information, Please! in reply to Dell (WA), 04-15-2007 10:21:55
Dell, thanks for the reply, but it has brand new spark plugs and points set at .015. Ran rough before changing all this and after changing there was no differance...
uh . . . Dell (WA)
04-16-2007 09:27:19
 Re: Information, Please! in reply to LoomismanOBX, 04-15-2007 23:07:12
Loomis..... ..did you not read..... .."according to Hakeem's Razor, its yer WEAK-SISTER ignition switch. $10 (cheap)..... ....Dell, yer self-appointed sparkie-meister
LoomismanOBX
04-16-2007 17:48:47
 Re: Information, Please! in reply to uh . . . Dell (WA), 04-16-2007 09:27:19
Dell, Ya talking about the KEY switch? Don't understand how this could possibly be the culprit... but thanks anyway...
Dell (WA)
04-16-2007 19:02:30
 Re: Information, Please! in reply to LoomismanOBX, 04-16-2007 17:48:47
Loomis..... ..yes, your keyed ignition switch is a weaksister and is causing WEAK SPARKIES which is causing your ruff-runnin' complaint.
Now I could do a long song'n'dance on how to "by-pass" the ignition switch with a jumper wire and alligator clippies to prove the switch is bad. I could also educate you on the "frailties" of the internal switch guttz, how they gitt corrosion over the years which cutts down on yer current flow to your ignition coil and causes weak sparkies. Generally, theres about a 15-minute timeframe for eazy start and then ruff-runnin' and quittin'. And about a 1/2-hr cooldown and the tractor starts right up.
Or.....in the interest of brevity, I cited "Hakeem's Razor". This is a 13th century English scholastic (mathematical) philosopher Ockham (also spelled Hakeem) who postulated the Razor: "Choose the most obvious solution first". Which is why I told you to change your weaksister ignition switch ($10, cheap) without the song'n'dance..... ..respectfully, Dell, the dance-master
