Not You, the Engine!
A. Bohemian
04-16-2007 16:41:44
Wait, if I read your post right, you think the oil fouling the plugs is perhaps coming from a valve?
Remember this is not an overhead valve engine. Oil from the valve train COULD get past a bad valve and seat, I guess, but I don't know if it would do so in the quantity you describe.
I still think you need a rebuild. Your compression readings may not look THAT bad, but I've seen cracked rings, for example, pass a compression test but fail under load.
Meanwhile, back at the valves; if you're going to do the rings, consider doing the valves at the same time. You're going to have everything apart anyway, and on an older vehicle like this, it makes little sense to do half a rebuild.
dave guest
04-17-2007 19:58:37
 Re: Not You, the Engine! in reply to A. Bohemian, 04-16-2007 16:41:44
Could be plug wire. Especially if using carbon or graphite wire. You really want copper. Sometimes the crimp is loose. Check with meter and wiggle the ends.
GB in MT.
04-16-2007 19:52:58
Thanks for the comeback A.B. I really appreciate the help. Looks like I'll be doing a rebuild as soon as I can afford it. I'll just have to live with it until then.
Thanks again.
Gary
dan hill
04-17-2007 05:46:09
 Re: Not You, the Engine! in reply to GB in MT., 04-16-2007 19:52:58
Slow down,A half pound dosent mean any thing.You may be running the wrong heat range on your spark plugs.Do you have a thermostat in the top hose.Ford tractors have gone from H10 to H12 on Champion plugs .I use autolite plugs,wont use Champions .They gas foul on cold startup.Put an Autolite 437 in #3 cylinder and see if the fouling stops.I had a 38 Ford that had just 40 pounds on all cylinders.I sold it to a friend who liked to race with early 50s Fords.None of them could pass the 38.Check into Aldor spark plugs on the internet.They make plugs that will fire in worn engines that are pumping oil.
A. Bohemian
04-17-2007 06:30:16
 Why Not? in reply to dan hill, 04-17-2007 05:46:09
Quote: "A half a pound does not mean anything."
I agree. Everyone who knows how to use compression tests as a diagnostic tool knows that.
However, what I said was, "Your compression readings may not look THAT bad, but I"ve seen cracked rings, for example, pass a compression test but fail under load."
Trying a different plug might work, allowing GB to delay a rebuild by some indeterminate amount of time.
But it will only mask the symptom, not cure the problem.
And, I"m fairly confidant one day relatively soon number three will miss all the time, even with NEW plugs...
dan hill
04-19-2007 01:44:21
 Re: Why Not? in reply to A. Bohemian, 04-17-2007 06:30:16
If an Aldor plug or an anti fouler would keep the tractor working ,Why not? This tractor could have a junk carbon core wire on it.An ohm meter test would spot this problem.Carbon core wire runs 10000 ohms per foot normally.
