Hakeem's Razor...Dell you lost me...
LoomismanOBX
04-16-2007 18:19:21
What exactly are you refering to??? You got me...
Steve Berthel
04-17-2007 13:10:16
 Re: Hakeem's Razor...Dell you lost me... in reply to LoomismanOBX, 04-16-2007 18:19:21
Since you guys are getting all philosophical with Occom's razor, KISS and such, how about the quote from the French aviator Antoine de Saint-Exupery:
"A designer knows he has achieved perfection not when there is nothing left to add, but when there is nothing left to take away."
Kind of a fancy way of saying KISS I guess
Steve
Dell (WA)
04-16-2007 19:13:03
Loomis..... ..I see the guys have explained "Ockham's Razor" aka "Hakeem's Razor" to you.
But to further explain: your keyed ignition switch is a weaksister and is causing WEAK SPARKIES which is causing your ruff-runnin' complaint.
Now I could do a long song'n'dance on how to "by-pass" the ignition switch with a jumper wire and alligator clippies to prove the switch is bad. I could also educate you on the "frailties" of the internal switch guttz, how they gitt corrosion over the years which cutts down on yer current flow to your ignition coil and causes weak sparkies. (Generally, theres about a 15-minute timeframe for eazy start and then ruff-runnin' and quittin'. And about a 1/2-hr cooldown and the tractor starts right up.)
Or.....in the interest of brevity, I cited "Hakeem's Razor". This is a 13th century English scholastic (mathematical) philosopher Ockham (also spelled Hakeem) who postulated the Razor: "Choose the most obvious solution first". Which is why I told you to change your weaksister ignition switch ($10, cheap) without the song'n'dance..... ..respectfully, Dell, the dance-master
RP-40-9n
04-16-2007 21:55:41
 del in reply to Dell (WA), 04-16-2007 19:13:03
my 9n has a toggle switch, is it also in that category? or is it just the original type switches that are weak? RP
Dell (WA)
04-17-2007 08:18:20
 Re: del in reply to RP-40-9n, 04-16-2007 21:55:41
RP..... ...most likely, yer toggle switch is mor'n adequate, my replacement marine grade toggle switch is rated 25-amps. But thats because I bought it and know how to replace it. Yours? who knows? The thing is the OEM and replacement keyed ignition switches are only 5-amps (barely adequate) and causes weak sparkies after years of wear and is the 2nd most likely cause of weak sparkies after bad ignition points..... ..Dell, the razor
LoomismanOBX
04-16-2007 19:36:22
 Re: Hakeem's Razor...Dell you lost me... in reply to Dell (WA), 04-16-2007 19:13:03
Dell, thanks for the insight. Will order the switch tomorrow...
Pooh Bear
04-16-2007 18:33:29
It's not Hakeem's Razor. It is Occam's Razor.
Basically it says, if there are two possible reasons for a problem, the simplest one is probably the true reason.
Pooh Bear
Justin Kelly Draney
04-17-2007 11:45:34
 Re: Hakeem's Razor...Dell you lost me... in reply to Pooh Bear, 04-16-2007 18:33:29
I kinda liked the "KISS" Theory... Keep it simple, Stupid!
Pooh Bear
04-17-2007 12:55:54
 Re: Hakeem's Razor...Dell you lost me... in reply to Justin Kelly Draney, 04-17-2007 11:45:34
I like KISMIT better.
Keep It Simple, Make It Fun.
Pooh Bear
DanL-Colorado-9N252085
04-16-2007 18:33:18
I used to just love using that phrase when I was trying to fix an airplane and the line engineers insisted on getting involved.
I think it's something they don't teach in engineering school; well, at least not the ones those guys went to.
I've always been a huge advocate of trying the quick/easy/cheap things first.
Of course, that brings up another old phrase: "Quick/easy/cheap. Pick any two, 'cause you can't have all 3."
Bruce (VA)
04-16-2007 18:45:29
 Re: Hakeem's Razor...Dell you lost me... in reply to DanL-Colorado-9N252085 , 04-16-2007 18:33:18
Speaking of fixing airplanes....my uncle, a radio operator on a B-24, 8th AF, WWII, was fond of this story.
After a series of bomber losses, a special team of engineers was dispatched from the US to an airbase in England. An old Crew Chief watched in silence as the young engineers crawled all over the badly damaged bombers, measuring & recording the size of every bullet & flak hole on each airplane. "What are you doing that for?" he asked. Obviously irritated at the question, the engineer snapped back: "We are plotting the exact location of the damage so that we can add additional armor in these areas". The Crew Chief thought about that for a minute & said "Well, you would be putting the armor at the wrong places. These planes made it back to England. Put the armor were there are no bullet holes ".
Probably a 'war story'....but I always thought it was funny!
Dan
04-16-2007 18:36:17
I use the "Quick/easy/cheap. Pick any two, 'cause you can't have all 3." all the time in my job. As a Director in IT - you always get pressured to cut corners.
Dan
Woodchuck
04-17-2007 06:13:39
 Re: Hakeem's Razor...Dell you lost me... in reply to Dan, 04-16-2007 18:36:17
Dan,
Where are you IT Director? I'm in IT at the University at Albany, Albany, NY.
Dan
04-16-2007 18:22:18
Hakim's Razor means 'With all things being equal , the simplest explanation/answer is normally the right one'
HTH,
Dan
LoomismanOBX
04-16-2007 19:28:30
 Re: Hakeem's Razor...Dell you lost me... in reply to Dan, 04-16-2007 18:22:18
Hey Dan... I liked that explanation... so my 1949 8n is: old/nimble/and cantankerous...Thanks for the reply...
Bruce (VA)
04-16-2007 18:30:43
Which is just the opposite of the cynical mis-quote usually attributed to H.L. Mencken:
"For every problem, there is a neat, simple solution, and it is always wrong."
What he really said was:
"There is always a well-known solution to every human problem--neat, plausible, and wrong "
The mis-quote is generally more applicable to life events, hence it's frequent use.
gahorN
04-16-2007 22:34:58
 Re: Hakeem's Razor...Dell you lost me... in reply to Bruce (VA), 04-16-2007 18:30:43
My ex-wife was quick, easy, and cheap. Until she found someone else who was too. ;Þ
