Andy MN, The NAA model was made in 1953 and 1954. Those made in 1953 are refered to as the Golden Jubilee model, or as the Jubilee (interchangeable). Jubilee engine is 134 cu in, 2N is 120 cu in. Not sure of the exact horsepower differences. Price varies with condition and location. Sounds like a good starting (asking) price. Tractor has both position and draft control. Differences you didn't ask about: Left foot operates the clutch, right foot operates both right and left brakes (can be simultaneously) Jubilees are the first Ford tractor to have live hydraulics. That means you can operate the rear 3 pt with the engine clutch depressed. Some later Fords also have live PTO, but not the Jubilees (except for a rare few with a dealer installed option). I bought my Jubilee last fall, before I knew alot about old Ford tractors. Dumb luck and a fed up seller got me a Jubilee with a trip bucket loader, box scraper and 8' back blade for $1,950. I had to do some work on the hydraulic pump and replace front wheel bearings this spring, but it was much easier with the help from this board. HTH, Mike NAA36663
