Spring Clip
8N joe in VA
04-16-2007 18:48:48
I lost one of the spring clips that holds the distributor cap onto my front mount 8N distributor. I've search the tractor supply sites I know about and tried TSC, with no luck. Does anyone know where I can get new spring clips without having to buy a new distributor?
JK-NY
04-17-2007 17:01:47
 Re: Spring Clip in reply to 8N joe in VA, 04-16-2007 18:48:48
Did you try your New Holland dealer(if you have one nearby)?
8N joe in VA
04-16-2007 19:06:33
 Re: Spring Clip in reply to Bruce (VA), 04-16-2007 18:52:00
Bruce
that part number says its for the newer 8N's with the side distributor. I have a front mount. Is it the same part?
dan hill
04-17-2007 01:42:45
 Re: Spring Clip in reply to 8N joe in VA, 04-16-2007 19:06:33
You may have to check the junk yards.I found that the chevy 6 clips fit the 42 ford v8 dist. with a little thinning .7RA prefix sounds like 6 cyl ford part.
BillM (OH)
04-16-2007 20:59:00
It is part # 9N12144 (clamp) for the front mount according to my book. Didn't go looking for it - hope you can find it - HTH.
8N joe in VA
04-17-2007 10:40:43
 Re: Spring Clip in reply to BillM (OH), 04-16-2007 20:59:00
Bruce was right. Just 8N's had the clip. He just had the wrong part number. Just 8N's carries the clips for both the front mount and side mount distributors. Thanks to all who responded.
8N joe in VA
04-16-2007 19:02:38
Thanks Bruce. I'm in Powhatan, about 9 miles west of rt 288 on rt 60.
