valve work
rod_in-IL
04-18-2007 08:10:20
I have a 1947 2n with an 8n motor front mount distributor and I am starting to do some motor work. I was wondering if anyone could tell me the proper way to lap the valves and if I should replace the 4 rotating exhaust valves with the fixed type. A mechanic here told me that the new gas has been causing the free valves to hydralic. Thanks for the help.
right wing pigeon
04-18-2007 10:12:27
 Re: valve work in reply to rod_in-IL, 04-18-2007 08:10:20
I dont know much but goin by part numbers on a gasket don't sound right. thair should be metal rings that outline the shape of the cylenderand valve chamber the side with the raised metal ring goes up this is to seal each cylender from oneanother at least thats what i remember
mad farmer
04-18-2007 09:21:27
Don't forget to check your guides first. If the valves wobble it won't matter how good you get the seats.
rod_in_IL
04-18-2007 08:15:16
Also I was wondering if it matter which way the exhaust valve springs go in. Does the tight coil part go up? And with the paper type head gaskets does it matter which way those go up? Thanks
Bob
04-18-2007 08:32:07
 Valve Work Questions... in reply to rod_in_IL , 04-18-2007 08:15:16
"I was wondering if anyone could tell me the proper way to lap the valves"
I would have a shop precision-grind the valves and seats. Then, NO lapping is needed.
Here's ONE type of seat refacer, that use:
Third Party Image
"and if I should replace the 4 rotating exhaust valves with the fixed type. A mechanic here told me that the new gas has been causing the free valves to hydralic."
NEVER heard of such a thing. Nothing "hydraulic" involved here.
"Also I was wondering if it matter which way the exhaust valve springs go in. Does the tight coil part go up?"
IIRC, the "tight" coils go towards the HOT area, which would be "UP", in this case.
"And with the paper type head gaskets does it matter which way those go up?"
GENERALLY, any printing... part #'s, "this side up", etc., goes "UP".
If NO markings AND the gasket is "symmetrical"... ALL holes line up the same either way, it doesn't matter "which way is up"!
