Order Ford 9N Parts Online
9n gov.
blitz
04-19-2007 16:23:21
the governor moves back and forth when I throttle up and down and it fights back when I move the arm manually. the balls are round the clearence is .223 there are no grooves inside the race and no slop in the arms on and in the boss and shaft hole. spring has slight tension at rest but when I need it to give me full throttle it doesn't move far enough to open the throttle plate enough to give me full power.
I'm stumped!! any ideas???
Jack-Illinois
04-19-2007 18:19:21
 Re: 9n gov. in reply to blitz, 04-19-2007 16:23:21
First you must have the linkage set so that with the tractor shut off and the throttle lever partially open (1/2 to 2/3) the butterfly on the carburator should be as wide open as it will go. If you are not getting this it will never keep the RPMs up when you load it.
blitz
04-19-2007 19:03:09
 Re: 9n gov. in reply to Jack-Illinois, 04-19-2007 18:19:21
I don't think I'm getting anywhere near that . I'll look and see what I can bend to get it.
IT seems to me that the rod might be to short as is but it worked great up until early this spring when I was plowing snow
blitz
04-19-2007 17:50:23
with the tach I set the max rpms at 2200 and when I'm riding it doesn't get over 1400.
Which linkage can I adjust? I've all but removed the gov. stop screw
Mine are solid rods with spring loaded sockets on the end.
thanks for any and all help
A. Bohemian
04-19-2007 18:38:31
 Ok. in reply to blitz, 04-19-2007 17:50:23
Quote: " with the tach I set the max rpms at 2200 and when I'm riding it doesn't get over 1400."
No, that's no good.
Thanks for the reply. I was just curious; you've already thought of everything I could have.
Bruce (VA)
04-19-2007 18:12:39
 Re: 9n gov. in reply to blitz, 04-19-2007 17:50:23
The 8N throttle shaft linkage has a threaded end; not so on the 9N/2N. Bend it to adjust.
Bruce (VA)
04-19-2007 17:28:55
You do know that you can adjust the linkage, right?
A. Bohemian
04-19-2007 17:39:05
 How Much is Not Enough? in reply to Bruce (VA), 04-19-2007 17:28:55
Do you have a dwell tach or other device you could check RPMs with?
