Whats the correct paint scheme for....
2-n
04-19-2007 16:59:52
A serial# 9n150251 - tractor?
where the starter/gen/acces painted black?
thanks in advance
2n
Lance in Brenham, TX
04-20-2007 22:04:31
 Re: Whats the correct paint scheme for.... in reply to 2-n, 04-19-2007 16:59:52
Click on link
Bob Harvey
04-20-2007 18:34:19
Like Dell said. Factory paint was the least expensive 'Henry' could find....not all greys, or reds are the same from production date to production date. There are MANY 'codes'. Your tractor.
Carl (NH)
04-20-2007 03:51:51
Sometime in the last few years, Tim posted this, which gives each part and the 9N-2N color and the 8N color. It's a little hard to figure out but usable.
Paint scheme for 9N/2N and 8N
Hope this makes sense,if was a word doc,so not sure how it will look copied to here..the first color listed by each item is for 9n/2n,second color is for 8n Tim
Part 9N /2N 8N
Engine: Fan Gray Red
Fan shroud Gray Red
Radiator Black Black
Radiator hose Unpainted Unpainted
Spart plugs Unpainted Unpainted
Fan belt Unpainted Unpainted
Generator Gray Red
Breather cap Gray Red
Head, block, oil pan Gray Red
Starter Gray Red
Wire harness Unpainted Unpainted
Distributor Unpainted Unpainted
Spark plug wires Unpainted Unpainted
Spark plug wire tube Cadmium-plated Cadmium-plated
Battery cover Gray Gray
Battery rack Gray Red
Ground strap Unpainted Unpainted
Battery cable Black Unpainted
Fuel line Unpainted Unpainted
Air cleaner Gray Red
Oil filter Gray Red
Fuel tank Cadmium-plated Cadmium-plated
Carburetor Gray Red
Manifold Gray Red
Transmission: Housing Gray Red
Gearshift Gray Red
Gearshift boot Black Black
Gearshift knob Gray Red (early)Black plastic (later)
Starter button Unpainted Unpainted
PTO lever Gray Red
Brake pedals Gray Red
Clutch pedal Gray Red
Running boards N/A Red
Differential: Housing Gray Red
Rear axle housing Gray Red
Axle hub Gray Red
Lug bolts & nuts Unpaintedor Gray Unpainted
Brake drums Gray Red
Three-point hitch Gray Red
Touch control lever Gray Red
Drawbar Gray Red
PTO shaft cover Gray Red
Front axle assembly: Axle hub Gray Red
Axle extension Gray Red
Lug bolts & nuts Grayor Unpainted Unpainted
Drag link Gray Red
Radius rods Gray Red
Tie rods Gray Red
Wheels and rims: Rear rims Zinc plated Zinc plated
Front rims Gray Gray
Sheet metal: Grill Gray Gray
Hood Gray Gray
Side panels Gray Gray
Toolbox Gray Red
Fenders Gray Gray
Fender mounting bolts Gray Unpainted
Ford emblem Silver scriptand oval edge,blue background Silver scriptand oval edge,red background
Ferguson emblem Silver letters,blue background N/A
Seat & assembly Gray Black
Radiator cap Black Black
Battery cover knob Chrome (early)Black (later) Black
Dash and instrumentation: Dash Gray Red
Switch and key Unpainted Unpainted
Choke knob Chrome (early)Unpainted (later) Unpainted
Throttle lever Gray Cadmium-plated
Throttle lever base Gray Cadmium-plated
Steering wheel center Plated acorn nut unpainted Plated acorn nut unpainted
Ammeter qauge bezel Black Black
Oil pressure qauge bezel Black Black
Proof meter bezel N/A Black
You can copy this and save it as a txt file for future reference.
Carl
Bob Harvey
04-20-2007 18:38:59
 Re: Whats the correct paint scheme for.... in reply to Carl (NH), 04-20-2007 03:51:51
'Hint'..... ..... .Grey
Dell (WA)
04-19-2007 20:58:46
While both the starter motor and the 3rd-brush genny were spray painted the same industrial battleship gray on the assembly line; REBUILT starters and gennys are painted BLACK by the rebuilders. Me? I say its yer tractor, paint'em enny color that pleases you..... ..Dell, the 20/20 painter (looks good at 20ft or 20mph)
Bruce (VA)
04-19-2007 17:11:40
None of those parts were black on the 9N or 2N. On s/n 9N 150251 (a 1944 2N), they would be the same color gray as the tractor.
