i can't really say how much weight i've got, but... it's a 641 with filled tires, and they're low on fluid. get's good traction usually. also have a heavy 7' hydraulic dearborn front plow. adds a few hundred pounds to the front end.... helps keep it down when i'm pulling. so, with that in mind, i've managed to drag some large tree trunks around in some sloppy conditions. best i recall is about a 24" dia. red oak around 20'long. this was done in about 6" of wet snow over another 6" of mud last spring. my method (and i've heard many differing opinions on the correct way to drag logs.... let's leave that for another time) is to use a drawbar on the lift arms, chain it up with the log and lift the front end of the log about 2". you can feel the weight shift back as the log comes up. the pull through the slop also included an intermittent stream crossing. as i crossed the ditch, the log touched ground, then the wheels spun. raised the log a bit and off i went. so... can't really say how much weight i was using, but it really helps. oh... as for steering, the muck was too much on the hills so it was brake steering in places. now for the disclaimers.... i pulled very gently, 1st gear, lower throttle. avoid jerking to avoid damage to the arms. one foot on the clutch at all times. one eye on the terrain ahead, one eye on the log end (to watch for snags). for what it's worth ike
