Order Ford 8N Parts Online
An 8N an Old Brush Hog and an ORC
Pete in OH
04-21-2007 04:50:53
I need some advice here. I"ve got an old 4ft brush hog with an equally old drive shaft. Both ends of the drive shaft are made to fit the 1-1/8" 6 spline. I"ve got an ORC that converts to 1-3/8" for the newer implements. I need to shorten the drive shaft to compensate for the ORC. But here"s the kicker, because the tractor side of the drive shaft is 1 1/8" I need to get a new yoke that will fit 1 3/8". Plus (yes it gets better) the welded on yoke and U-joint that fits the tube half of the shaft are so corroded that I need to cut that off and replace it too. I looked at TSC and CNH for a new drive shaft but the cheapest I found was around $200 and it still won"t fit the 1 1/8" spline on the brush hog. I"ve already bought the parts to rebuild the drive shaft for about $90. Before it"s too late to return the parts do you guys think it"s worth all the $$$ and time and effort to fix this thing?
JoePilot
04-21-2007 15:53:32
 Re: An 8N an Old Brush Hog and an ORC in reply to Pete in OH, 04-21-2007 04:50:53
Something to consider: the back of the tractor is 5 feet wide. With a 4 foot mower, you can't really get close to fences, trees, etc. I use a 5 footer...
Joe
lonestarjeff
04-21-2007 09:56:46
My .02 would be return those parts, sell the "project" 4-footer to someone else, & find a ready-to-go 5-footer.
You'll likely save money & have a better package to get the mowing done.
Jeff
Dell (WA)
04-21-2007 08:41:29
Pete..... ..you do realize the very NECESSARY ORC for brushhoggin', comes in 4-sizes don't you? Oldfashioned 1-1/8F input and 1-1/8M output. Newspecs 1-3/8F input and 1-1/8M output as well as yer current 1-1/8F input and 1-3/8M output. Go shoppin' ($60, cheap)..... ...Dell, the ORC preacher
Dan
04-21-2007 06:05:42
You can replace your entire PTO assembly with 1 3/8" splines for about $100...
Dan
Dan
04-21-2007 06:07:08
 Re: An 8N an Old Brush Hog and an ORC in reply to Dan, 04-21-2007 06:05:42
Never mind - I just re-read the post and saw the cutter side shaft is the old standard... Need coffee.
Dan
CT8N
04-21-2007 05:22:31
If you get it fixed you will only have a 4 foot cutter. An N will pull a 5 foot with ease.I have seen many good looking brush hogs sell for $200 or less at auctions here in MO.
Charles
