Order Ford 8N Parts Online
help please 48 ford 8n
richmond in
04-21-2007 13:43:17
went to lift my grader blade today and it wont lift it. it tried to but wont. but if i help it it will lift it and holds it up in the air good. let it back down and same thing wont lift it but if i help it will. fliud is full and looks good. thanks for any help. jason
Dan
04-21-2007 16:39:01
 Re: help please 48 ford 8n in reply to richmond in, 04-21-2007 13:43:17
Remove the right hand inspection cover and watch inside while you try to lift the blade. Look at the bottom close to the pump and see irf you see a bunch of swirling oil. I suspect you have a blown saftey valve since you say it holds it up fine once it is up.
HTH,
Dan
