Cyl head Gasket
9N 89716
04-21-2007 14:09:04
Finally replaced the gasket and torqued down the head, but now I have <30 psi compression, where I had >80 before tear down. Have a steel head gasket from NAPA, did not use any gasket sealant.Head and block surface are clean, torqued nuts down to 55 ft lbs center out. Any suggetsions would be appreciated.
Dan
04-21-2007 16:40:35
 Re: Cyl head Gasket in reply to 9N 89716, 04-21-2007 14:09:04
Did you put the gasket lip around the cylinder holes up? Tighten again, if you can get it started run a bit and tighten again.
Dan
