Wow.
A. Bohemian
04-21-2007 18:31:38
I started to operate a "bush" or "brush hog" (Central Texas Bohemians call it a "shredder") as soon as my legs got long enough to allow me to fully depress the clutch on our John Deere MT without bumping the power lift controls; say, age eleven.
I guess the worst thing that ever happened was when I was shredding our little fifty-acre home place near Cypress, Texas (long since paved over and lost in a sea of urbanization). I was working over one little overgrown pasture that was isolated in a clump of trees.
Unknowingly, I passed over a ground bee nest, hidden in the dewberry vines. Then, I drove around the pasture and came back over it a SECOND time.
They were waiting for me.
I killed the tractor as soon as I recovered from the first shock; but I was unable to wait for it to come to a stop, so I jumped off SIDEWAYS and ran off as quick as I could.
Before I could get away, they stung me eleven times IIRC; I do remember having seven stings on the head or face.
If you've ever driven a two-cylinder Deere, you know that big old flywheel will drive the tractor some distance with the ignition off, even with a shredder hooked up and the PTO in gear (come to think of it, the shredder blade and heavy gearing on that tough old Rotocycle probably added MORE momentum).
This is especially true if the motor has some wear, which the motor on the Deere certainly did (it had spent its first twenty years as the only tractor on a 90 acre cotton farm on a bluff overlooking Rosebud, Texas).
This, coupled with the delay shutting off the ignition resulting from my surprise, meant that when Dad went back to get the tractor, it was a good thirty feet away from the nest and the ground bees were ignoring it again. So, Dad didn't get stung once. Nic!
Yes, I finished shredding the next day. With one eye swollen shut.
Lance in Brenham, TX
04-21-2007 19:23:03
 Re: Wow. in reply to A. Bohemian, 04-21-2007 18:31:38
How true! I grew up around Brenham, Texas and thought people called it a shredder everywhere. "Bush Hog" is a brand name, right.
A, Bohemian
04-22-2007 08:02:03
 Re: Wow. in reply to Lance in Brenham, TX, 04-21-2007 19:23:03
I'll bet you've seen those ground bees, too, although hopefully you're not as familiar with them as I am.
I've got other stories about those bees, but they are too far off topic, even for me!
Dunk
04-22-2007 06:02:48
Even a Pepsi is a Coke in GA. LOL
Ross Pugh(NC)
04-22-2007 04:16:38
Right, Bush Hog is a brand name, they named it after the bush hog.
