Order Ford 8N Parts Online
8N sidemount spark plugs
Andy (MN)
04-22-2007 11:50:31
I'm thinkin' of puttin' in an order here on YT , lookin' at a tune up kit #309787. comes with Autolite 216 plugs . I was thinkin' I needed 437's like the kit for front mount has. Wonder what the diff is ?
Carl (NH)
04-22-2007 18:37:26
 Re: 8N sidemount spark plugs in reply to Andy (MN), 04-22-2007 11:50:31
I would recommend the AL-437's myself. They are supposed to have a hotter tip and are less apt to foul. I used to run Champions (H-7's maybe? - don't remember now), but after reading the advice here and on other forums, the AL-437 really is the best choice. It's good to have a spare set of plugs available anyway, so you could get the kit AND buy the AL-437's, then keep the other plugs for spares. If you ever flood the engine while trying to start and foul the plugs, you can take them out, put in the others to get going, and once the engine is warmed up, switch to the fouled plugs. The hot engine will burn off the deposits and you'll be okay again. Some people say they use a propane torch to heat up the fouled plug tips and clean them off that way. Whatever works!
Carl
john hunt
04-22-2007 12:45:32
it what you like to use ... I use what every come in the kits , I have use 216 autolite and they work great. I have use ac,nkg, etc. I like nkg over all. champ I don't even use them champions plug.. the last set champ I weld it on 1 1/2 flat bar about 2 ft long with a 5/8 hole in it to check if the the fire from the dist work great as tool ...
john hunt
04-22-2007 12:39:31
it what you like to use ... I use what every come in the kits , I have use 216 autolight and they work great. I have use ac,nkg etc. I like nkg,over all. champ I don't even use them champions plug.. the last set champ I weld it on 1 1/2 flat bar about 2 ft long with a 5/8 hole in it to check if the the fire from the dist work great as tool ...
