Order Ford 8N Parts Online
1951 8N SEAT SUSPENSION
donoliver2
04-22-2007 19:24:57
MY 51 8N HAS A PAN SEAT BUT HAS A DIFFERENT SUSPENSION THAN I HAVE SEEN ON ANY OF OTHERS I HAVE SEEN. IT BOLTS TO THE TRANS CASE IMMEDIATLY BEHIND THE SHIFT LEVER WITH A SHOCK JUST PAST THE MT. & THE BIG COIL SPRING UNDER THE PAN SEAT. IS THIS OEM FORD?? OR AFTER MARKET?? THANKS,
DON
Willy-N
04-22-2007 20:14:55
 Re: 1951 8N SEAT SUSPENSION in reply to donoliver2, 04-22-2007 19:24:57
third party image
This seat was made by Knoedler Manufactures, Inc., Streator, Illinois it was on a 1952 8N I had once. There are several diferent types that were put on as a after market add on. Mark H.
HA DON?
04-22-2007 20:04:33
Did you know all caps is just like YELLING????? ????
donoliver2
04-22-2007 20:18:28
 Re: 1951 8N SEAT SUSPENSION in reply to HA DON?, 04-22-2007 20:04:33
Sorry if I yelled at you guess i know less about computer etiquette than I know about 8n fords.
But thanks for your input.
Dan
04-22-2007 19:55:53
third party image
Does it look like this? This is a Monroe (as in the shock company) EZ-Ride seat. This was a dealer installed option. Do a search of the archives here to follow my challenges and info on how to repair and restore it.
Dan
jerrycpp(WA)
04-23-2007 11:04:23
 Re: 1951 8N SEAT SUSPENSION in reply to Dan, 04-22-2007 19:55:53
My 8N has one like that except the shock goes towards the back and connects to the "ear" on the right side of the top link. This seat was originally on my dad's 9N and when he traded up (1955) he made the dealer put this seat on the 8N. The mounting brackets did not fit the transmission, so they put a couple of bolts up through the top cover of the 8N. Is mine also a Monroe? Sorry - I'm not where it is to take a photo.
Dan
04-23-2007 15:27:13
 Re: 1951 8N SEAT SUSPENSION in reply to jerrycpp(WA), 04-23-2007 11:04:23
There were two versions of the original Monroe EZ-Ride seat. One for the 9N (the kind you had) and the 8N (pictured). they mounted a tad different, but were made by the same company.
Dan
donoliver2
04-22-2007 20:21:22
Dan, Thank you very much for your help that is exactly what i have.
Thanks again,
Don
