Hi guys, long time no see. It was a big weekend for me and Old Warrior. He came outta the garage this weekend and earned his keep for the first time. I hooked up a really old junk 5" generic bush hog to him and started on the 55 acres I have been cutting regularly for a few years now. I was really pleased with how well he worked. Dan, that problem with the lope at 1500 and 2100 was completely cured by retorqing the head bolts (they all needed 1/2 turn plus) and replacing the rebuilt original carb with a new black cast iron carb from Tisco. I looked at that carb for about a year before I screwed up the courage to install it and face the music if it dodn"t do the job ($250), but it is fixed! OW ran at 1500 all day through tall thick grass and the governor coulda taken the day off. Coming home, he ran up to 2200 and cruised along the road in 4th gear like he was on a road trip, smooth as silk. So anyhow, since he is doing so well, I think it is finally time to invest in his future with a new bush hog, so I will start up, once again, one of our favorite debates, with a few twists.I"m concerned that some bush hogs may hit the rear tires when I lift it, and I am concerned with that as well as making the front end too light on that high speed run home with it lifted high. Some bush hogs offer "offset" 3pt hitches. My big JD MX6 has a 3pt mounted at an angle leaning forward, is that the fix for hitting the tires? As far as weight, I do have a front bumper, and the famous foam filled front tires to add some significant weight to the front, but I"m thinking about a 6" squealer, and it is not light. The new cutter also needs to be Quick Hitch compatible, as I am completly spoiled with the JD iMatch system, and have bought a QH from Tractor Supply that looks just great on the back of OW, and come to think of it, adds a few inches of offset to the rear 3pt, which may help with the rear tire thing, but the old junker is QH incompatible, so it is currently mounted old school (and hits the rear tires when lifted too high), with anti sway bars and limit chains, all of which will work with the QH system. So help me out with experience and opinions guys. Long post, sorry, had a lot to say after so long away. Thanks!
