The basic design of the engine in these tractors dates back AT LEAST as far as the Model N Ford automobile of 1906. Various versions of this engine were in production for about fifty years! And perhaps as many as 750,000 of them are still running all over the world, in N series tractors, Model A and T Fords, irrigation pumping stations, power generation stations in remote areas, etc., etc. Of course, Model N tractor engines have some important improvements over the original Model N auto engine, such as a Kettering ignition system, better cooling system, more power and torque, and a much more flexible RPM range. Nonetheless, when you start an N series tractor, it sounds almost exactly like a Model T or Model A Ford! I hope you enjoy your tractor. I do want to endorse what some others said about using a hay buggy to move round bales as opposed to lifting them with the hydraulics; a typical round bale is close to the maximum capacity of the system, and one of the surest ways to prolong the life of ANY old vehicle is to avoid operating it near, at, or over capacity whenver possible. Buy an owner"s manual and read it, cover to cover like a Grisham novel, as soon as possible. Then, get an FO-4 shop manual; you"ll need it eventually, you might as well already have it on hand when you do. Finally, when the day comes and the tractor won"t start or pull well, and Dell tells you to replace the ignition switch, just take his word for it!
