If I Am Reading Your Posts Correctly...
A. Bohemian
04-23-2007 17:47:52
(1) Blown gasket (which has been replaced, but probably resulted in extreme overheating at the time)
(2) Difference in compression between cylinders
(3) Zero PSI with oil at fill level
(4) So much blowby oil and white smoke are flying out the filler neck
I would STRONGLY suggest you stop running this engine under load, immediately. It's done.
You can and perhaps should do those compression checks; but you KNOW there is excessive blowby, and rings occasionally check better than they actually are. So, the test could give misleadingly encouraging results.
I think you need a rebuild. You might be able to put it off for some time, but if the difference in compression between cylinders is great enough, you run the risk of messing up the crank and/or block, which can greatly increase the cost of a rebuild.
